PanamaExpat
- May 28, 2011
So I finally got around to sticking a light bulb on the thing to count the flashes. I am fairly certain the CEL is burned out as it has never come on. If I am reading the codes correctly I am getting a 32 (EGR test fail) then 75 (BOO Brake on off signal shorted to power) and a 22 (MAP or BARO signal out of range). The 32 may be the reason I get some light stumble and an occasional stall when I drop off the throttle while driving with the AC on.
So if i am reading this right (32) something with the EGR isn't working right. I am thinking it might be the solenoid. I will test that in a few and see.
For the BOO code (75) I have no idea so unless someone knows I'll be Googling for a while to try to get a handle on what could cause this.
For the MAP (22) I am figuring that since everything is basically redone it probably relates to something wrong with the EGR system as I just cleaned up and reused the original. I didn't even know my 94 4.0 had a MAP.
Mind you all of these codes could be in error if I am reading it wrong.
Suggestions, solutions clues? Anyone?
Well not sure at all now.... The 75 code suggests that the brake lights are stuck on.... Not so as they work just fine. ????
Maybe I should be looking at 3 digit codes.... 327 still indicates EGR or DPFE issue. Most likely DPFE.
522 Neutral switch is not working and I am aware of that.
