- Jul 27, 2008
- Alaska
- My credo
- Shit Happens...Then You Die.
Make sure your anti-freeze is mixed to the proper ratio, for your area. If to diluted, your radiator may be freezing. What is the outside temperature where you are? I had the same problems as you and found that my glycol tested down to -25 degrees but the outside temp was -50 degrees. Use a tester not appearance.
