 - Oct 15, 2020
 - New York
 - 2.9 V6
 - Automatic
- Total Lift
 - 2.5" Suspension
- Tire Size
 - 31 x 10.5 x 15
Ok. I actually didn't rotate the engine to any partiular position yet, just reached in and touched those lifters and a few spun.Yes, those are the pushrods
Yes, either mis-adjusted or collapsed lifter
That's why the adjustment is set from 0 lash and then 1 and 3/4 turns, not based on pressure feedback from pushrod/lifter
Rotate the engine more and test other pushrods with valves closed, to see what the average "tightness" is on the pushrods
I've still got to learn a thing or two about observing the valves for this. I know i need spark plugs out but i have to go through the lessons of valve location. Will probably consult Haynes if they have a section. But once i have that down, I'll make a list of which rods are easy to spin and when. Maybe having a chart of that information will shed some light on my noisy engine.
Would collapsed lifters quiet down as engine warmed up and oil flow improved? Or would collapsed lifters simply always be noisy? Reason i ask is because my engine does get pretty smooth, not tapping or noise, a lot of the time it's driving.
