- Sep 4, 2010
- South Georgia
- Manual
I think there's a thread on here somewhere that was several pages long, discussing the pros and cons of each locker.
nice build cant wait to see more
after more research i think Ive answered my own question, yes the locker can be installed into an open carrier, the only issue i noticed that people were running into were that the higher the ratio of gearing you go the thicker the ring gear is. the thicker ring gear makes it impossible to remove/install the pin without having the carrier out and the ring gear off. i have seen the revised pin with material cut away from it to allow it to be removed. but that in turn would sacrifice strength in the pin itself. another way is to shave down the inside of one tooth allowing the pin to come out as well. thankfully i am rebuilding the diff prior to installing the new gears and locker. so it wont be as big of an issue until i go to take things apart. lol
just ordered my front spindles and spacers and rear shackles from canuck. im going to call around and see if i can find a good place to order my locker, gears, and rebuild/shim kit. any suggestions from people who have ordered them in Ontario?
also looking for poly bushing for my leafs, anyone know of a company that makes them for the 98+
ive got 4.56's and my gear comes right out. dont run a 4.56 unless you have ATLEAST a 33. or your highway rpm will be 2800.
cannuck is great to deal with, if you need help i have the same spindles. do the bearings and BJ's while you have it appart. as for locker... try summit?
need to order my rear gears ASAP, decided to order them from summit, have everything lined up, is this all correct for my 95 explorer 8.8 31 splin axel?
http://www.summitracing.com/parts/RMG-8002791/
http://www.summitracing.com/parts/RMG-8310431/
http://www.summitracing.com/parts/RMG-F88456/
let me know guys! thanks! i just have to get the approval from you all and push order![]()
looks good to me. but use rvt not that gasket for the diff.
