Factory rear lift blocks...
JoseBronco
BroncoII 4wd coil springs and Explorer leaf springs for a Ranger 2wd
I have a 2wd Ranger with the front end sagged down.
On my spares pile I have a pair of Rancho 2.5 inch lift coils for a BroncoII 4wd, and a factory leaf springs of an Explorer.
I would like to know if that coils and leafs bolts on the Ranger without modifications, and how much lift can I expect (I had reading something about 2wd coils are higher than the 4wd ones).
Thankyou.
Coil springs between 4wd and 2wd trucks are the same height. Those lift coils will fit your Ranger. The leaf spring will fit your truck as well but will give you a harsh ride unless you like to carry heavy stuff. You will probably get right around 2in of lift all around if you install all of that. Just wondering though, do you have a supercab or regular? And what engine as well. That will help in determining the approximate amount of lift.
Oh, it is a 1991 with regular cab and the 2.3L I4. It is all original without modifications or additions, except for a Brahma hardtop over the bed.
Thankyou for your help!
