lilblueskeeter
- Sep 21, 2017
I'm working on a 96 2.3l manual trans 2wd. It started a few days before Christmas. Went to start it and it just cranked and wouldn't fire up. It was driven a few days before and ran and drove fine. After messing around trying to get it started I put it in clear flood mode and it started and died. It would only stay running if you gave it quite a bit of throttle and it smelled rich. So I pulled the plugs and decided real quick to replace them. They were shot. Some were worn down so bad the gap was at .080. After replacing the plugs and wires it would start without putting it in clear flood mode, but still ran horrible and still had to feather the throttle to keep it running. I put a code reader to it and it showed the coolant temp sensor reading -45 degrees so I replaced it and now seems to be reading correctly. I really was hoping that was it but it didn't change anything that I could tell. It still smelled like it was running rich. I was able to take it out for a drive although quite difficult was able to drive it about a mile before I decided to come back before I got stranded. It didn't want to run at low rpm, ran really rough but ran great at high rpm. I've pulled the plugs a few different time through this ordeal and none of the plugs were wet or smelled of raw fuel. I checked the FPR for fuel in the vacuum line and it was dry. I've cleaned the MAF sensor. I've done a few other tests but can't recall everything at the moment. I'll update as I remember them. I appreciate any help I can get. Thanks in advance.
