Had to replace the transfer case shift motor on my 98 Ranger. The transfer case has a single wire coming out of it that does not go to the 8 pin connector from the motor. I can't find a shift motor that has this extra wire. Had to get one without it. It shifted and the lights work, and low range is low range. BUT, after reading another post here, it seems the wire is to sync the front axle to the rear. Does this mean that while I am in low range (or even high), I'm only in two wheel drive? I just shifted it and drove about 10 feet to check if was in fact in low range.
Can anything be done to make this motor (and 4X4?) work without having this extra wire? It seems all the motors were rebuilds from Cardone, which is no longer...
