lil_Blue_Ford
Cut & Weld
⭐Supporting Member
💻 TRS Socials
TRS 25th Anniversary
- Aug 6, 2007
- Butler
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- 5.0L
- Automatic
- Total Drop
- 4”
Interesting.The transfer case is the one that came in the truck back in Jan of 1998 when I bought it with 14 miles on it. Now at 368K, it's been falling apart. LOL
I use to live further out of town on a gravel road that was very steep, so I was always shifting from 2 to 4 high so as to minimize potholes in the gravel. Never had problems then, but that was back in the 2010s. Now I hardly think to put it in 4 wheel drive.
Couldn't tell in the video, do you remember if your connector was 'full' of all 8 wires? Thinking now that I need to look at the new plug on the motor and see if all 8 wires are 'filled in'. If so, I'll try splicing the 'extra wire' in the new motor's plug into the one from the transfer case. Sound logical?
Yes, the 2000 transfer cases that I had which didn’t have the extra wire from the t-case only had 7 wires in the plug and a blank spot. Dad’s 99 had the extra wire and it filled that last spot. Which is why I asked if your truck had 7 or 8 wires on the truck side, if it had 8, then that’s likely where the missing wire goes. If it has 7, then adding a wire to the plug won’t change a thing because there’s nowhere on the truck side to connect. If that makes sense.
The wire colors changed randomly on the shift motor side. Depended on who made it and when. They can be traced out but should come pre-assembled into the correct position.But the wire colors on the new motor don't match the original, as far as positions go. And the original plug on mine only had 7 wires installed. So there was one 'blank' in the plug, and the extra wire was the 8th. Was thinking maybe they integrated it into the plug on other years, since your description of the wires don't match my plug. What do you think?
