Explorer to B2 5 speed swap
Featured Build Threads
Kwazie
Southern Maryland
Looking to do a auto to manual tranny swap. Found a donor 93 EB and know the trans will swap but what about the other parts like pedal assembly, master cylinder and steering column? May need the shafts too due to M5od vs A4LD length but not sure. Going into a 90 B2 that is showing signs of pending failure. I have read here of swaps using ranger or b2 parts but no info on Gen I Exploder except engine swaps. Can I use it or do I need to keep searching?
Your shafts will work, as long as you dont swap the 13-54 T-case from the Exploder in also.
The 1st gen Explorer used 2 different masters. An early and a later one. A 91-92 master is the right one for your truck, but I would get a new one.
Also replace the slave while your there. Dont play with used parts.
Featured Ranger Based Vehicle
