Explorer supercharger on an 03 4.0L ranger?
in actuality, fuel mileage does increase with boost, EXCEPT, when you get into the boost hard, alot of people cant resist hte pedal once they tinker with they're vehicle, but if you baby it when you drive supercharged will help fuel mileage a little.
What suprises me is that nobody has ever taken up my sickest idea of all time....
Take a 4.0 block and a 2.9 crank turned 010/010 to the the 4.0 spec,
have custom rods and pistons fitted into it.
This would produce a low compression 3.3 liter V6 with ENORMOUS boost tolerance.
built as an OHV (the SOHC involves crank snout differences)
"Out of the box" with stock 4.0 camshaft it should produce 330-ish at 15psi.
Of course for a lot less money you could build a 5.0 or 5.8 to do the same thing and wouldn't be peppering innicent bystanders with shrapnel from your exploding transmissions. (please note the use of the PLURAL here)
Voluntarily giving up 42ci is sick (IN A BAD WAY) to me, supercharged or not.
It makes sense to me that you should build it since you thought it. I wouldn't be suprised if you already had most of the parts to build the engine. :D
You won't... :stirthepot:
Pete
That indicates to me that you are pretty much clueless about forced induction
in specific and engine design in general
Airflow generates torque.
Torque at rpm makes power.
Less displacement allows FAR lower compression and thus far more boost(mechanical comression is the enemy of boost)
Giving up 42CID is literally trivial when considering that the engine in question would be run at TWICE atmospheric pressure.
the shorter stroke would allow the engine to be more "Revvy" like a 2.9
the 4.0 is not dynamically stable above 4500rpm
and what limits the 2.9 is it's breathing.
So you'd have the revability of the 2.9 with the breathing of the 4.0 heads
not to mention the taller block which would allow longer rods
Quite often displacement causes more problems than it solves.
In this case the major limiting factor is how much torque you could force through the gearbox (gearboxes only care about torque) before it would break.
Like when I was playing with my Saab I could have increased boost, instead I ported the hellout of the head put a fairly long overlap cam in it, retarded the cam timing and went for top end power.
Why? because the transaxle would tolerate 225-250ft/lb of torque.
PERIOD, so I decided that 220ft/lb of torque at 4800rpm was far
better than 220ft/lb at 3200rpm.
Bear in mind that this represents a near doubling in power,
WITHOUT grenading the transaxle.
How much is enough?
IF you cannot get it to the rear axle, let alone to the ground,
it's pretty much not worth having in the first place.
Boosting a 4.0 would generate more torque but it still
wouldn't be able to rev without tearing itself apart.
and would do a better job of converting transmissions to schrapnel.
Even at the lower boost that would be possible in a full size 4.0.
AD
