Do this instead:Ive heard people taking the supercharger out of an explorer and swapping it into their ranger. Is this possible on a 4.0L. Direct swap in or im sure theres modifications? Also would there be better gas milage?![]()
Do this instead:
http://www.boosthead.com/product.php
No, your gas mileage would not be better. With the additional power you are going to keep your foot in it. Even if you feather it, it will still take a little more fuel. shady
Does anyone know where you can find the OHV supercharger?
What suprises me is that nobody has ever taken up my sickest idea of all time....
Take a 4.0 block and a 2.9 crank turned 010/010 to the the 4.0 spec,
have custom rods and pistons fitted into it.
This would produce a low compression 3.3 liter V6 with ENORMOUS boost tolerance.
built as an OHV (the SOHC involves crank snout differences)
"Out of the box" with stock 4.0 camshaft it should produce 330-ish at 15psi.
Of course for a lot less money you could build a 5.0 or 5.8 to do the same thing and wouldn't be peppering innicent bystanders with shrapnel from your exploding transmissions. (please note the use of the PLURAL here)
