exhuast gaasket
bmudrock04
any links out there to do this on my own would help out cause i cant afford to take in and have it done. spoke with mechanic and i need to get the upper and lower ones replacede. thanks Brian
upper and lower....he must mean the manifold and "donut".
its pretty straight forward.....unless you break exhaust studs off in the head...then its no fun and can take some tools (drills, torches, taps & dies) to fix.
unbolt the manifold, replace gaskets, install manifold.
You may have meant to say Intake gaskets. they are the upper and lower. On a 92 they are probably in need of replacement.
yep definately a manifold gasket upper and lower thanksfor the reply's .... so any links to step by step instructions for that quick fix
