kunar
Forum Staff Member
well, 3 questions.
How much is too much?
What causes it?
How do you fix it?
Basically i have a clunk coming from the right rear and the only issue i can find in the area is a lot of end play on the axle shaft. i just wanted to try to figure out if this may be the problem. i havent even had the cover off yet but i think when i do i will change seals and bearings. (is there any way to get them out without a slide hammer?) anybody got any suggestions for me? its an '87 7.5" rear with 4.10 gears, limited slip.
What causes it?
How do you fix it?
