That's a pretty vague reason. How about a list of items? What problems? Why do you believe that they are poorly designed.
problems:
OHV Engine.
-cracked heads
-intake gaskets split fill oil with coolant takes out bottom end
-rocker arms and push rods wear into each other and rattle bad
-rear of intake gaskets leak oil
OHC Engine
-timing chain issues (all 3) cassettes brake, primary gets sloppy, tentioners go bad,
-vacuum leaks at intake all years, and at egr tube.
-heater shut offs go bad overheat happens engine usually junk.
-vibration dampers break engine vibrates bad takes out main bearings
-just a few examples.
-pain in but to work on.
poor design when went to ohc engine. when it was a ohv engine it was based off 2.9l engine. when went to ohc it was a completely redesigned engine, instead of going to the modular engine (4.6, 5.4, 6.8) design, they design the pos we are stuck with today. could have had a 6.8 v10, take off 2 cyls have a 5.4 take off 2 more have a 4.0 all intechangeable parts (pistons, rods, front cover, basic engine design but they went a different more expensive route, the modular engines by then were developed and good. they had to recast the block to accodate timing chains front and rear with a jack shaft and some a balance shaft, the modulars have 2 chains both up front much better design and easier to work on. plus now with the 4.0 to time it properly you have to spend $500 in special tools for all the holders and aligners and it is quite a project if you dont do it all the timme and it is too easy for something to slip. modulars mark the chain the way in the book telss and line up the marks no special tools need. i think it was a poor shot at a redesign engine
just my 2 cent
