My 1994 2.3L SFI (California only) won't start all the time.
I purchased a replacement motor and did not know enough to look at all the connectors on the harness. The old harness is no longer available.
There is no connector for the cam position sensor on this harness and the motor came with a cover over the mount hole for the cam sensor.
Is the cam position sensor required? Why would the mount have been blocked?
The truck ran but it would die randomly at any time, it would start everyday for weeks then it would not start, then the next time I tried it would start. my 1994 2.3l sfi (california) Ranger xlt pick up
I have changed the fuel pump, the fuel relays, the PCM, the MAFS.
The last thing I did was change out the PCM and then it ran for one night and now will not start again.
With the ignition on the fuel pump is not running, if I jump the inertia switch it still does not actuate the fuel pump. If I jump the relay and power the pump it won't start any way. There is spark but it seems a bit weak, but as I mentioned it seems to run just fine intermittently.
I am at the end of my skill set here any suggestions would be great.
If you need any more information please just ask I will gladly provide what information I can.
Thanks Rick
Thanks Rick
