What if you live about a mile from the Mason/Dixon line and work on the other side?
You marry your cousin quit your damn Yankee job and remove the thermostat altogether, scares the squirrels .
I wouldn't run a 180degF t-stat in a newer Ford.
The whole point of the thermostat is to get engine up to 200degF ASAP
Once any t-stat opens you have all the flow you are going to get, so 180 or 195 have exactly the same cooling flow.
The 195 just gets engine temp up to 200degF faster so better MPG and lubrication.
180 t-stat might not even get engine up to 200degF on a cold day, so you would be burning money.
On a hot day it wouldn't matter, 180 would work but so would 195, so.......best result all around, 195
If I lived where outside temp was 80 to 120degF year round I would remove the t-stat, better flow
......and, of course, more squirrels
