Justins87
Will a 2000 3.0l 2wd ranger motor bolt in a 07 3.0l 2wd ranger? And if so can I stay with the 07 wiring harness?
Thanks for that info and no either one is not flex fuel and the 00 motor will be going into the 07.Yes, for the most part. Upper and lower intake manifolds were slightly different between those years, so you'll probably want to swap over the '07 parts if you can. The older stuff could be made to work but will require some small changes so using the stuff from the 07 is probably easier than coming up with a bunch of small work arounds.
If one of the trucks is flex fuel and the other is not, then you'll need to swap the injectors too.
