engine swap- transmission doesn't have hole for speed sensor
StrangerRanger256
I'm deep into a 302 swap into my '94 ranger and have run into a bit of an issue trying to get the speedometer hooked up. The truck uses a cable driven speedometer, but the transmission doesn't have a hole for any speed sensors. It's a M5ODR2 out of a 2wd '96 F150 and only has a plug for the reverse light switch- nothing else.
So, my question is- could I put a new tailshaft housing on that is set up for a speed sensor?
Seems like I just might be screwed until I do the 8.8 swap and use the speed sensor on it and put in an appropriate speedometer... hooray, more money to spend.
You could try finding a tail shaft with the speed sensor in it but you would also need to change the output shaft in the transmission
Yes, you can swap in a 95 or older M5ODR2 tailhousing. Your 94 instrument cluster is cable driven, so using the abs sensor in the rear axle is not an option for you...
SVT
This is from another site(F-150) with different information on years and parts needed for mechanical speedometer.
"It's very simple, I did it when I put a '96 tranny in my '87. You need the tailshaft housing from a '88-'91 M5OD transmission, which has a mechanical speedometer. Also the speedo gear and clip from the tailshaft and the small bearing that keeps the gear still on the shaft."
I think 1991-1994 Rangers had the combo Cable/VSS on the trans, VSS was used for PCM and Cruise control, cable was just for speedo/odo, R1 or R2 shouldn't matter, they should use the same unit.
Picture of it here: http://www.therangerstation.com/tech_library/speedometer.shtml
thank y'all much. I'll be headed out to the junkyard tomorrow to see what I can find.
