jd6gun
- Aug 20, 2011
This is a 1990, 2wd, manual, regular cab, 2.3 EFI, ac(removed years ago). Truck was stored 4.5 years. Filled it with gas installed a new battery and drove it for the last 7 months cross country around 8000 miles-no engine problems. Recently died at a traffic light. Several failed starting attempts led to parking lot trouble shooting. Tried to read codes, but the test connector wires are in poor condition and cannot get codes. Checked the fuel relay fuse in the power distribution box-it is good. Checked the inertia switch-not tripped. The fuel gauge has been erratic since brought out of storage, so I suspected the pump. Changed that out. No joy. Checked the old pump out of the tank-it worked. An assistant helped me check for spark. He saw no spark. Tested the Ignition Module-it is good. Have been told the Crank Position Sensor could be at fault as well as the Fuel Pump Relay since it is in the ignition circuit. The Crank Postion Sensor is going to need more than my little travel tool kit in a parking lot to replace. I purchased a Fuel Pump Relay, but cannot find it under the hood or in the Haynes book. For some reason, I also suspect the oil pressure sending unit. I have not researched this as far as the ignition circuit, and I think the presence of the inertia switch may negate the idea of low oil pressure(presumably being due to an accident) shuts down the pump and the ignition. But, if the part is cheap and easy to replace, mine is twenty years old so why not?. Is there anything I am overlooking other than an open circuit due to broken wires which is next after a few quick cheap part changes? QUESTION: Where is the Fuel Pump Relay on this vehicle?
