- Aug 28, 2008
- Automatic
okay, an update....the engine is out. Oh my lord, now I realize you only need to take the top nut off on the mounts to get the engine out
I took several hours trying to get that lower one off. Then I un bolted the mount from the block, and once I pulled the engine I realized I did not even need to do that. Also some else that I found helpful is to pull the Transmission dip stick tube out, it really gets in the way of one of the trany bolts.
Now I have a few questions. The engine I am putting in the ranger is from an 88 and it has an egr tube coming out of one of the manifolds. But the truck I am working on is a 90 and it does not have an egr tube. Am I missing something? Does the 90 not have an egr system? If not I will remove the tube and plug that hole in the manifold. Anything else that may differ on the two engines I should know about?
