getmoney06
- Feb 4, 2010
my truck seems ot miss or just stop running while under load, i cant go past 60 at times and spits and sputters goin up hills even just slight hills, i dont know if its engine trans or fuel but ill start here , when i push in the clutch and reb engine it revs up just fine but when goin down the road and i give it gas its acts up even if i go push the as in just at 1/4 way down ,im also thin kin about replacing the ground how many are there and what should i replace them with any special wire ??
