engine blowing air through vaccum lines
jle621
engine blowing air through vaccum lines rough idle no loss of power 91 ranger 4.0 auto tran
Sounds like plugged exhaust. Probably cats.
Might waant to do a compression check,timing chain check after disconecting exhaust at manifolds.
Hook a vacuum pump to the manifold or a vac line. If you have anything higher in pressure than 20 inches of vacuum (yes, I know that is fuzzy grammar but I'm assuming it won't be understood anyway) then you have a massive exhaust restriction.
