Electrics Dead
Final Update: RonD/Adsm, you are the men. Yanked the alternator, took it to AutoZone #1. They don't have the patch cable to test it. Really? For an F-150? Down here, that's like every second vehicle down the road. Took it to O-Rileys. Both of their patch cables are broken. Took it to AZ #2 and it was only putting out 11.4 volts - which is the exact thing RonD told me to check and their numbers line up with mine. O'Rileys said my battery was good, AZ said it was weak. I replaced them both. I really couldn't believe how easy it was to do. All I really needed was a 10 mm socket, an 8 mm socket, a Phillips screwdriver (which in retrospect, I didn't need at all), a flat blade screwdriver and a 1/2" breaker bar to take the tension off of the serpentine belt. If I hadn't been running around to half of the auto parts stores in town, it would have been easily < 1 hr. I even put it all together with a flashlight under my arm. Anybody seen my trouble light?
Those are some of the easiest alternators to do.
Heck yah. Piece of cake. Ask me about the starter on my Maxima. I couldn't even find that sucker until I dove onto the internet. I'm still looking for my trouble-light.
I bet you can put your new Alt. & Battry in before i can :icon_bounceblue:
At least when you go to that excellent mexican food place now your truck will start, grande margarita time bro.:icon_cheers:
If you stop calling it a trouble-light you might find it...it thinks it's in trouble so it is hiding...call it a work light and it will call in sick but at least you will know where it is...you may need to trace the call though...
