oleblue
I know I'll probably get pounced on for asking this from reading around here, but how many of you have electric fans and what do you think about them? Do you get better gas milage, more power etc?
the stock fan output varies depending on engine rpm. no electric fan will ever match your mechanical fans output...whether this becomes a problem for you or not depends on a lot of factors (climate, a/c use, driving style, traffic, ect).
some guys have had cooling problems after switching to electric, some havnt.
as for power/economy, no. the stock fan is attached to a thermally activated clutch, meaning the fan is only causing drag on the motor when the motor is in need of airflow for cooling (just like an e-fan kicking on and causing a higher load on the alternator, and thus drag on the motor).
