I know the E-Fan has already been purchased AND will be installed…
E-Fan have a lot of good things about them but there are two things that got the best of me and an E-Fan will be the last thing I install and only if nothing else will work.
The first is the white noise (static) that the fan injects in the Communication Radios in my last truck, CB/Ham/Scanner, the CB being an AM device was the worst.
The second thing was at highway speed the E-Fan would actually stop some of the air from coming through the radiator causing the truck to run at a higher temp.
The truck this happened in was an ’88 Ranger STX with a 5.0L in it and I used the E-Fan because of the space involved but my truck would heat up more on the highway when it should have been at a lower temp. It never boiled over, never went above the 210 on the gauge but that fan ran all of the time on the highway and you could hear it from the cab.
If we were to vote on this I would vote a mechanical fan if at all possible, E-Fans have their place and a lot of people use them without problems, so i guess they are here to stay.
your blower motor and ignition system had no noise combined? try shielded wire and straight feed from alt with all wiring out front on the core??
you are a perfect example of why people will insist their is some inferiority with electric cooling because you have been there and done that....and only that and never pursued anything to figure out if there was an alternative issue... thats perfect and i am glad you posted this experience
and
YOU and
MEshare the same results for specific applications, because
WE ...or at least myself is an ignorant knuckle buster ape. thinkin you a do it get it done guy anyway at the least.
the only problem with your truck and my truck when this situation was occurring was you and me...we were the problem.
i am not sure if you tried mechanical fans or not but i certainly did, various types and all failures for various reason along with various radiators.... ...and depending on situations it was actually worse for some, better for others. the mark 7 mechanical fan is a monster for cooling, and it got its ass kicked too, funny how the upgraded mark 8 vehicle with 80 more hp and even more weight to haul around didnt have a mechanical fan, and comparatively it had NO grill to let air in. but overheating wasnt an issue.
must be pure coincidence?
no, i didnt think so either.... but i kept aimlessly mixing and matching based on flow nubers etc not fully understanding that "potential" for max ratings is key in the more is better game... ..
this is where all the other factors come into play, fin density being a huge player along with core type and material.
these days i can cool your truck with the mark 7 mechanical fan perfectly, or a taurus fan perfectly without the issues you describe.
figuring out the right components is very important. proper installation even more so. the e fan running when on the road is curious, manually cut off with a blocking diode may have been all that was needed. not sure of the setup you had.
that is a 351 cobra r radiator externally mounted, so one would have to think at hiway speed cooling would be a non issue. even at 90 mph with a 7200 pound cruise weight with tools etc....not overly aerodynamic either.
this is just a lucky shot that will fortunately show the extremes i went to to see what works and does not for ranger cooling.
this is a typical load, not even close to heavy, and i covered alot of ground that way and in many cases the engine ran all day to power air and electric tools.
i am confident with cooling advice, been swapping bigger engines into these since the late eighties early 90's.
so you wont get me to agree with your conclusions on the v8 ranger cooling subject. it appears you simply gave up?
if you still have this i am willing to let you experiment with a setup i have in the barn. its beat to hell but still effective.
proper installation of good matched components is the key, and its quite possible this op may end up another e fan hater with the selection he made, or maybe he will be happy...
see what happens
