bobbywalter
TRS Technical Staff
TRS Event Staff
TRS Technical Advisor
TRS Banner 2012-2015
Ugly Truck of Month
TRS 25th Anniversary
- Aug 9, 2007
- woodhaven mi
- Automatic
- Total Lift
- sawzall?
- Tire Size
- 33-44
- My credo
- it is easier to fix and understand than "her"
Alright, now that I figured out how in the heck to put a pic on the site, thanks to my 12 year old daughter,
There are many reasons i chose to go the switch route. First, the t-stats and relay will fry, as mine did. Put a lit, 20 amp rocker switch on it and you will have no problems. Also, simplicity of installation. A power and ground wire is all you need to get the fan going. If you were to go the switch and t-stat route as I first did, you would need to run 4 wires in and out of the cab to the battery and switch and fan. Just a pain.
Last, as was previously pointed out and by no means a small point, you can turn the fan on and off as needed. Whether you need to cross a river, safely stick your hand in the radiator, or need max cooling because of stopped traffic, you have versatility. All for the cost of a 20 amp switch; about $5.00
Better heat in the winter, better cooling in the summer; not sure there is much more to say.
The switch pics are one on and one off. It has a red l.e.d. when it is on just as a visual reminder. I have a grey interior with black trim so i chose a black switch. It really blends in nicely. Most people do not even notice it.
THIS IS HORRIBLE ADVISE. it will get an equally shitty result in the long run as the cheap ass relay setup originally tried that failed..
you would have to be fan specific to do it....using a 5 dollar switch to carry that load that distance is not a great idea even with small fans. a large fan will burn it up....of course you just twist the wires together to get ya by, but theres much better ways to do this.
my fan would eat a 20 amp switch in a month or two of hot city traffic. might last ten years up here though. eventually i would just leave it on so i didnt have to worry about it....whats the point in that??
