- Aug 28, 2007
- Durham, NC
- Automatic
OOOH! OOH!... forgot to tell you... I think the RKIs/super-mods will back me up on this:
Now that you have the new sensor in, you need to disconnect your neg battery terminal for 5-10 minutes, then re-connect, so your PCM "learns/calibrates" values from the new DPFE, and "maps" it in with the other sensors... *then* you'll notice the diff... not right away, but after a few miles of driving... made a HUGE difference on my install... went from rough-running POShyt to Swiss watch.
When you disconnect the negative battery cable from the battery, if you touch it to the positive battery terminal for a sec. or two, this will discharge the filter capacitors in the PCM for the unswitched 12V, resetting the PCM.
You can also disconnect the negative battery terminal with the headlights on, and this will do the same thing. This eliminates the long wait for the capacitors to discharge by providing a discharge current path.
