ssny1088
- Nov 10, 2015
Have a 97 ranger w/2.3. It sat for several years and had many elect. issues due to dirty contacts, and may have another. Has ran fine for approx. 1 month but now it cuts out/stumbles and check engine light blinks(while stumbling) Does this cold,hot..etc. Radio,others stay on so not losing all power.Checked ignition switch box (seems fine) bypassed eec relay, still same. I tried this as I can turn on key, w/motor not running, and occasionally engine light flickers off, fuel relay and iac valve cycle. Seems to me eec is losing power/ground. It has 104 pin eec marked CSY2. Also swapped PCM diode w/ABS diode.Same. Anyway to direct wire EEC hot/ground to bypass possible wiring issues? Hate to start swapping parts, especially the EEC needlessly. Sorry so long, wanted to give all info.
