[EEC-IV] ECT/IAT VREF Showing 0.21v, TPS 2.8v at WOT
forgedoffroad
Forum Member
Baton Rouge
LA - USA
Vehicle
Drive
3.0L
2"
31x10.50R15
I'm not even sure where to start here.
My 1994 Ranger STX (currently 4x2, but planning to [finally] SAS it later this year) with 3.0/M5OD started getting super weak a few years ago. I really don't drive it very often, but I really do love this damn thing and refuse to give up on it for sentimental reasons.
I've built Crown Vic station wagons in the past, 5.0HO and T5 swapped them, so I'm familiar with the EEC-IV system, but I'm far from a pro. I have an off road shop, so I'm usually more focused on suspension, tires, armor, etc.
Sorry- anyway... quick backstory: in December 2024 I replaced the fuel injectors on the Ranger and did a full tune-up... it has had a misfire since I acquired it in 2005, but it was running a bit more rough (and significantly slower) than usual at the time. In mid-2023 I installed all new A/C components and I replaced the entire ignition system, including the distributor, hoping that would clear up the misfire, but it didn't work. From there, I was hoping that a set of new injectors (I was still running the originals from 1994 after countless periods of sitting for months on end), a quick tune-up, and valve cover gaskets would have my kid set up to drive it for a few months in a pinch... but once I cranked it with the new parts, it ran 5x worse than before. I do think the new injectors simply amplified whatever was happening before that, but it's hard to say. I ran a compression test and thought #6 was super low, but that turned out to be a bad test.
It has sat at my shop since, until a couple weeks ago I decided to clean it up and start digging into it again. After an extended thrash session last weekend, I made some electrical progress when I discovered that the RABS module has failed and appears to be shorting to ground. That is currently disconnected until I can get a new module.
As far as the testing I've done...
All six injectors are firing (we did find one that was testing fine on the bench, but not installed, so we replaced that one) correctly.
All six spark plugs are firing correctly.
Timing is set (I can't remember exact advance without the pill, but it was standard- maybe 8-10*?)
Fuel pressure is 32psi (I know that's on the low end of the spectrum, but it still shouldn't run this ridiculously rich)
The (new Motorcraft) ECT is receiving 0.21v on the 5v circuit. There is no resistance on the wires from the sensor connector to the ECM connector.
The ACT is receiving 0.21v on the 5v circuit. There is no resistance on the wires from the sensor connector to the ECM connector.
The TPS is receiving 5.02v on the 5v circuit, but only sends a max of 2.9v back to the ECM at WOT. There is no resistance on the wires from the sensor connector to the ECM connector.
The MAF, when checking the ground into the ECM, is only able to carry 0.21v on that wire (that's with DVM + on battery + and DVM - on the signal return wire to test its ability to ground to ECM) There is no resistance on the wire from the sensor connector to the ECM connector.
The O2 sensors have no resistance on the wires to the ECM, no resistance to the grey/red combined signal wire, and elements pass resistance tests.
I checked the (I see 4) ECM grounds from the connector to the ground locations and all show zero resistance.
I removed, thoroughly cleaned, and re-installed the following harness ground locations:
Left fender (two between the starter solenoid and the ECM)
One at the radiator support near battery
One in the right kick panel
One in the left kick panel
I added 6ga (welding wire) grounds from the block to the cab (firewall), the block to the frame (original location), the frame to the cab (at the radiator support w/ the battery and harness grounds)
I'm not currently showing any sort of grounding issues anywhere, despite that everything I know about EEC-IV is telling me this is most likely a ground issue.
I got to the point I had decided it needed a new ECM, so I ordered one... and it's doing the same thing (not that anyone is surprised.)
I'm frustrated. I'm exhausted. I'm losing shop time because I keep trying to check one more thing. Does ANYONE have ANYTHING else to contribute as a possibility to test? I checked with all my old Ford tech buddies and no one has a breakout box I can borrow to make things easier, either.
I found that the evap canister purge valve was showing some extreme resistance so I replaced it and the soft hoses. It's now idling significantly smoother, but I'm still having the low VREF issues throughout the engine bay.
I still have yet to find any wiring with resistance / open loop issues. The only thing left that I can think of under the hood is the ignition control module.
It's interesting... I've found probably a dozen issues in this whole process. Things I would have otherwise never found since they were so minor, but they're all getting resolved as I find them.
Now, to figure out what's causing my "electrical choke"...
Well... as it turns out... the refurbished ECM showed up with the exact failure my original ECM was suffering.
New ECM should be here Tuesday. Hopefully I'll be able to move on in life at that point.
  • [EEC-IV] ECT/IAT VREF Showing 0.21v, TPS 2.8v at WOT
What is the common failure in both ECMs?
The truck ran “okay” with both, but both had the 2-wire sensors receiving ~0.2v instead of 5v. TPS still had 5v but maxed at ~2.8-2.9v at WOT. Injectors, ignition, everything still worked like normal… just a weird idle and fairly limited power, even for a Ranger.
In the ECMs I could follow the 0.2v signal from pin 7 (ECT) and I think pin 25 (ACT/IAT) up the veins a bit, but lost them because everything got too small and I don’t have a desk magnifying glass like the people who actually know what they’re doing with circuit boards would have. 😂 I was trying to figure out if it was something I could fix but at the point I couldn’t even f***ing see it, I threw in the towel.
The replacement ECM should be here Tuesday, then hopefully I can actually drive this thing until the 4x4 swap once I’m done with my YJ.
Well, back to the drawing board. The second replacement ECM is doing the same exact thing. I also brought my little battery and ECM power/ground harness I made to the junk yard and tested an EEC-IV ECM from a '95 Mustang and it's giving me that same 0.21v on pin 7 for the ECT so my assumption is that I have got to be doing something wrong here... but I can't figure it out.
I've checked every pin on every connector on every harness I can find under the hood against every other pin on every connector on every harness I can find under the hood. No continuity between wires (except the wires that actually connect to each other, like the GY/R, R, etc)
The LG/R going into the cabin (I believe it's ignition switch) shows some continuity to ground (32.2 ohms resistance) so I'm about to pull the ignition switch to test that, but I'm not sure that's going to do anything for me either.
What shape are your injector connectors in? Are the pins wore out or maybe not seated in the connector all the way?
The injectors are firing great. It looks like the enhanced misfire when I replaced the injectors was due to one that was testing fine on the bench (clearly audible click) but wasn't firing correctly in the truck. I even moved it from #5 to #4 to make sure it wasn't a pin issue. I replaced that injector and it helped significantly.
What I fixed so far:
I had the alternator and starter rebuilt (broke the stud off the alternator during testing)
I replaced the evap canister purge valve along with the soft hoses for that (I believe this was the bulk of my issues causing it to run so rich)
I replaced the PCV valve on the driver head
I replaced the ECT and connector with the updated versions
I replaced the TPS and connector (I hadn't yet realized that the voltage issue was deeper than just a bad TPS reading)
I pulled, sanded, cleaned and re-installed all grounds I could find (the book lists nine, but I didn't pull the cowl to check those, yet)
I added 6ga welding grounds from head to firewall, block to frame, frame to radiator support, and battery to fender
I unplugged the internally-shorted RABS unit
I replaced the ECM... twice
I'm still getting low voltage. However, it occurred to me Monday night that it's entirely possible the ECM is running on the "safe" tune since it keeps getting unplugged and essentially resetting. I put everything back together yesterday (wires are simply ziptied neatly out of the way of all moving components) and cranked it up, adjusted the idle/timing back to ~700-750 idle and 10* BTDC, and drove it. Despite the weird voltages, it actually drives really nicely, so I'm thinking it may be possible that with 100 miles or so and some fresh fuel, it could be good to go. I'll drive it through the weekend (my two younger boys are insanely excited to ride in it, for whatever reason) and see what the voltages look like after it's had time to relearn everything.
I'd forgotten how cold the A/C gets in this thing- while driving it home I had to turn off recirculation and drop the fan speed to #1 so I wouldn't freeze myself out!
I know my 2000 ranger with EEV-V takes a couple drive cycles to return to a normal idle and stop hanging the RPM with the clutch in after having the battery disconnected for a while. I chased my tail for a week trying to fix the hanging RPM issue
It triggered a CEL on my way home last night...
KOEO test shows Code 118: Engine Coolant Temp (ECT) Sensor circuit above maximum voltage/ -40*F indicated.
When I checked the voltage at the ECT it's showing 0.18v (it reads the same whether the DVM is on GY/R wire or battery negative)
No wiggling of any wires causes any fluctuation whatsoever.
It's a new Motorcraft ECT with the updated connector and the sensor resistance is spot on for temperature.
The G/R wire from the PCM to the ECT shows no resistance and carries enough current to power a headlight from the sensor connector to the ECM connector.
I individually unplugged each sensor on the G/R signal return wire and nothing changed.
I shook the shit out of the harnesses and nothing changed.
KOEO shows 0.06v on the GY/R signal return wire. I don't know if that's high, normal, or low.
Don't know if this helps but I'll go check the KOEO voltage on my 2000 3.0 right now
With the engine running, my Ford Fuel Injection & Electronic Engine Control book says I should see 3.0-11.5v on the W/LB wire from IAC to ECM (engine warm, idling, revving upward of 3,000 RPM) but it's gettting almost the full 13.98v the VPWR wire is showing. I'd swear I unplugged the IAC at the beginning of all this drama and it caused the RPMs to drop, but it's not doing that at this time, despite passing all other tests. I'm going to grab a new IAC and see if anything changes.
I got 1.7v with it cold. Edit* gauge says cold but I drove it almost 2 hours ago
After not getting anywhere with the newest ECM I pulled it back out and opened it up to check the capacitors. I was trying to avoid that for any potential warranty issues.
One capacitor climbed to (I think) 32.2k ohms and stopped. The other was having a party inside and never settled on any reading, just like the blown capacitors in the original ECM.
Unfortunately, the manufacturer doesn't have any more on hand, so I'll have to look for another source. There isn't a single '93-95 Ranger with 3.0 in the nearby junk yards, otherwise I'd take my chances on one of those.
Just to follow up a bit... the third reman ECM (I switched from Blue Streak to Cardone) worked properly, but it was still running very rough.
As it turns out, I had sensors and fuel injectors that were dropping out as we were testing/correcting issues. My assumption is that the renewed voltage from the few minor wiring repairs and improved grounds were more than the old electronics could handle. Maybe. I don't know. We finally had to constantly go back to square one with testing from scratch every time we replaced something, just in case it triggered a failure somewhere else in the system.
In the end, we replaced seven sensors that "passed" tests in the beginning of this resurrection and four injectors had failed during the initial driving phases (I'm expecting all six would have died at the rate they were going, but by the time the third one went bad I ordered enough to replace the remaining injectors.) The injectors didn't have 200 miles of drive time on them, but I can't even remember what brand they were (I want to say Bosch, but I can't find a receipt anywhere.)
Anyway... the first fill-up from getting it running at all showed 10.2mpg... after getting it running properly, the fill earlier this week showed 15.6mpg, so I'd say we're good to go. I wish I could still get the 18-20 I was getting when I first got it, but that was on the baby tires and 14" wheels. While still nothing crazy, the 31s are something like 5-6" taller than factory and the 4.10 gears are a little deeper than I was intending... and I'm not turning off the A/C.
Nonetheless, it's good to be back in Papa J's old Ranger. I think this weekend I'm going to take it all back apart and re-loom all the engine harnesses, now that I'm confident we've got it running correctly.
Next will be leaf spring and shackle bushings, then cab bushings... then I have to decide whether I'm going to build one of the F100 Dana 44s I have, or just swap in one of the XJ Dana 30s, or call Giant and go with a fully retarded TTB build with the 4x4 swap.
