- Aug 6, 2007
- State - Country
- GA - USA
- Vehicle
- Ford Ranger
- Automatic
- Total Drop
- few inches
- Tire Size
- ~30"
Spotted a set of Edelbrock E-Street heads on Craigslist a few hours ago, and wandering if I should scoop them up for my V8 swap.
From the listing:
Emailed inquiring about mileage, them being disassembled, and having "better springs". This was the reply:
The way they look in the pic I can believe 0 miles. I've read about the spring issue so that seems legit, but I don't know enough about valves and shaving heads to know about the rest.
I'm particularly interested in these for a couple reasons.
1) Price
2) lighter weight
3) No spark plug issue with regular headers (want to run Tri-Y long tubes)
Any other pros or cons?
Will these work on the Explorer motor? Thinking about valve clearance and camshaft. I know that I'll have to get new pushrods.
Would these heads play well with the Explorer EFI system until I can get it tuned?
Would they still work well together if went ahead and installed say an E303 cam? If I installed a set of 1.7:1 rockers
The motor going into my 86 ranger is a higher mileage 5.0L from a 98 Ford Explorer with the GT-40P heads. The plan at current is to use the Explorer EFI system, and install the motor with existing manifolds to get it running and drivable. After getting the bugs worked out I was going to get cam, heads, headers, and possibly rebuild the bottom end if it showed signs of needing it. (I don't think that it does right now based on the way that the Explorer ran.) If I got these I'd probably stick to the same plan, but it'd happen much quicker. FWIW I'm going for a lowered 2wd street truck that can double as a daily driver.
From the listing:
http://images.craigslist.org/01010_dCRTiLii6SR_600x450.jpg
Edelbrock E street heads are dissemble but I do have all the valves and better springs to put them back together $ 550 all parts included .
They have 0 mile I did not finish the build I change the spring because the springs that come with them are no good.The spring that I have to replace the ones that came with the heads are good for about 500th lift.They have the 2.02 intake valves the heads have been cut .025 with flat top piston that will give you about 9.5 to 1 compression and the valves have a 20 degree back cut.
1) Price
2) lighter weight
