- Feb 11, 2021
- Seattle, WA
- 3.0 V6
- Automatic
- My credo
- Keep your mind like an umbrella, it only works if its open... Continually learning.
Been busy fixing issues with the truck that have been showing up. Lots of maintenance stuff too.
March I installed a F150 turn signal stalk because my knee kept hitting the ST T/S stalk.
In April, alternator was making noise after washing it. Serp belt was cracked so I just replaced the lot. Belt, tensioner, idler, and alt. Also found a gas cap leash at the junkyard so I installed that too.
In May I replaced the Brake Light Switch and Oil Pressure Switch. Brake light switch was causing the shifter to stick and the o/p was causing fluctuations in the gauge. Or so I thought, found out it is just an on/off switch. I have an oil leak that I haven't found (haven't looked too hard yet) but I'm thinking it's the RMS or pan gasket. Hoping for the pan.
Also started getting a misfire and finally got a code P0303. Replaced the plugs and wires, plugs were gapped .027 to .033 and FSM says they should be .061 to .067. 1st mistake was buying cheapo wires. After install I got a P0301, 3, 4, and 5. Ends would not snap on to the plugs. So, I ordered ford wires. Ran a lot better but still had the miss on #3. Ordered an injector, when it arrived, I went to install it and found the sleeve was cracked. Ran down to the parts store and shelled out way too much for the sleeves but got the sleeve installed and the miss was gone.
Unfortunately, 2nd mistake was not buying injector O-rings for the other 2 injectors. Ended up with an O-ring leaking fuel. So, tore off the intake again and replaced the 1 and 2 injector O-rings and sleeves.
Maintenance wise during that I replaced the t-stat housing and tensioners, and had a small victory.
End of May, I broke the dr. window while mowing the lawn... what was worse I broke a window on the topper as well. (sigh).
June, I started the process off hooking up a rear backup camera.
