swynx
I wanna say that its an old tale but no worry. Top gear? Or the myth busters? Did a segmemt on cars in the cold. I let mine warm up tho. Can't hurt
If I may ask what is it in the carburetors that make them not run right when cold. Whatever that is the efi must not have it
For some reason I couldn't quote this from the post...but, anyway, as mentioned by racsan the choke plays a big part in the start/warm up...but my truck hasn't had a choke since I put the current carb in...and it simply will not start in cold weather...anything below -10* C and I can crank it all day and it won't start without manually choking it...but if I plug the block heater in and let it warm up for about an hour (depending on how cold it is) it will start every time first crank...
So I think part of the problem has to do with block temperature...and carbs will NOT run properly without a bit of a warm up after starting...mine spits, sputters and sometimes stalls if I try to drive it right after starting in cold weather...
I have said it before, I will say it again, and there is now, and I'm sure always will be, some nay-sayer that disagrees. Carbs were a neat idea in their time. Now they are an obsolete throw-back to a century past, nothing more than a toilet bowl you bolt on the top of your engine.
I am not a nay-sayer that disagrees that EFI is awesome....... when it works...but when something goes wrong it is a PITA to troubleshoot.
