I have a 2000 Ranger 2wd 3.0v6 5spd manual, and I was wondering if it is better to down shift when coming to stops or if its better to just coast in neutral.
My S-10 has gone over 200K on the original calipers and discs, and the discs were never turned. Still stopped fine, even in a few emergencies. Unless the discs are scored or warped, I believe it is a waste to turn them. I know I'll get some discussion on this.
that all depends on how often you want to be replacing brakes, Ive had a set of pads last me 2 years without wearing down to metal by using a combination of both coasting and down shifting
Steep downhill grades is the only time I ever use gearing on a ranger to slow the vehicle down. A 2-ton truck uses the gearing to keep from heating up the brakes. Lightweight vehicles have no reason to use the gears.
Big JIm
