Does underdrive pulley require a different belt?
Fruitbox
Im installing an underdrive pulley on my 94 3.0, my truck has A/C, can anyone that has installed one tell me if they had to change the belt length and what length belt they used? Thanks
Yes. Because the pulley is smaller, you'll need a shorter belt. The belt size depends on the pulley you use. If you're buying it new, the seller should be able to tell you what size would be required.
Thanks, ive been reading arguements about this mod for a while now and I think I changed my mind, im going to be lifting my truck with larger tires so my rpms will be lower. I wanted to free up some HP but im already installing an electric fan, i dont want to take the chance and mess with the waterpump speed, expecially since most of my wheeling is low rpm.
Your torque will be lower as well.
I wanted to free up some HP but im already installing an electric fan, HP
You won't notice anything different, especially using larger tires.
