Disconnecting the rear ABS
Will the brakes still work fine if I remove the fuse and unhook the sensor?
But yes you do need to remove and by-pass RABS module brake line interface with a new brake line.
Why?
My RABS is 100% non-functional, but the RABS module is still there in the line. I don't have any issues.
And you are obviously still alive, and I assume driving this magic truck, so I guess you would not need to disconnect or bypass the brake lines
Lol, which does make sense since RABS "limits" rear brake pressure when activated so the only change would be possible lock up, which would occur with or without module in the brake line
I've seen them have a bunch of stuck crap in them. I would remove it, but it's your call.
Posting from the Galaxy.
