disciplerocks's B2 build thread
Yeah it was just an idea I was throwing around.
yea, i used to have a 01 explorer and for a while i just had about 4"s of lift and 33's i used to hit the ubolts and shock mounts on a ton of rocks. i eventually went with a sas to cure the problem haha...
Just some prices for those that are curious.
Superlift brackets $100
brake lines and tee $35
entire D35 axle including manual hubs, calipers, radius arms, driveshaft, and steering linkage $90
entire 8.8 explorer axle including drums, driveshaft, and core $70
shortened front drivshaft and new u-joint $42
thats come good deals man! are you lookin to buy extended arms or build your own?
I dont know. Manufactured ones are pricey and I don't own a welder.
i dont have a welder either. im just collecting all the pieces cutting everything and bringing everything to a local shop to get it all welded up.
do you have any pictures of the extended brake lines you got from autozone? id like to see them.
I will shoot one with my phone and load it later.
sounds good man. thanks. good luck with the build.
Here is the passenger brake line.
Spring perches welded. Thanks again Greg. You can see where they used to be.
Picked up new u bolts for the larger axle, axle fluid and a new u-joint for the rear driveshaft.
And just for fun....what my truck would look like with 33s
yea. im going to have to look into getting those brake lines mine are not long enough as it is and after my arms are extended they deff. wont be.
whos 33s?
Greg's (97TrailRigDD) And if you get them brake lines, you have to get a tee for the drivers side. Part number BLF-58C.
8.8 in and almost ready to drive. Ran into some driveshaft problems. I am hoping I don't have to have a new one made.
Both axles together.
Did a google search on the u-joint that I needed to make it work. Found several sites that all said to use 1-0134. Just got back from Autozone and I don't think it is going to work either. Still too big.
Apparently the joints in my shaft are 1210. So now what do I do?
