disciplerocks's B2 build thread
Ok so I sourced a free starter for the 5R so I will be swapping the pump and bellhousing over. I like when things work out without costing anything.
I hope it works for you.
Robert
posted while in the restaurant at the end of the galaxy.
Installed, and still nothing. At a loss.
Check and make sure the transfer case is in gear, it might be in neutral, I have seen it happen.
Robert
posted while watching the Simpsons.
D, do you have a line pressure tester? If not, you may have to borrow one to make sure the pump is putting pressure. Did you put new seals in with the pump?
SVT
No not the starter, the pump. I have the lines diconnected and nothing is coming out.
But I think I figured it out last night. I realized I didnt get the flexplate spacer from Jon. Forgot that the auto used one when I installed it.
That will do it....
SVT
Yeah it had to be something stupid.
Look at it this way, you've upgraded to the 5R bellhousing and starter :icon_thumby:
SVT
Lets hope this is it
Event Coverage
TRS Merch
