- Aug 6, 2007
- Age
- 49
- Berrien Springs, MI
- State - Country
- MI - USA
- Manual
- My credo
- If you can't go through it or around it, then go over it.
I've got the 7.3L and oddly enough, specs I've seen weigh it less than the 6.0L (taken before accesories). Guess all the EGR equipment gets heavy.
Never was a big admirer of the 6.2L... all of 'em I've driven were rather gutless. Liked the turbo-6.5L tho. Didn't even know they were candidtes for a Ranger swap... that's a big V8!
talk to Will. he has contemplated it, measured it, him hawed ....... he will know more about it.
a N/A 6.2 is gutless. a 6.2 with a non-wastegated turbo that has been bored .040 over (mil spec remman, makes it a 6.3L) with a 93 injector and lift pump, 4" turbo back exhaust and some other easy/cheap mods and the engine will breath fire.
just ran the number on putting one into the Bronco and it came out less money to swap in a 6.2/6.5 hybrid turbo to get get 200 RWHP and 380 RWTQ than than swapping in a cammed 351 to get the same numbers..... plus you can run it on B100 or 95/5 mix of filtered used motor oil (95% FUMO/ 5% diesel fuel) with no problems
[EDIT] hp and torque numbers assume the use of the 6.5 TD vin "F" (non EGR) intake manifold and no intercooler (not needed with the non-waste gated turbo [/EDIT]
