- Jan 24, 2018
- Tallahassee Florida
- Manual
- Total Lift
- Stock 2"
- Tire Size
- Stock
- My credo
- Doing things wrong, until I get it right.
It also had a trunk where the Probe had a rear hatch.
Welcome Visitor! Please take a few seconds and Register
for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
It was the name of a concept vehicle, from'79Also, who came up with the name "probe" and were they in the middle of a prostate exam at the time?
They would sale the sh!t out of a V8 Ranger if they make it 4x4 with colored tow hooks and skid plates, and a sticker on the rear quarter panel, apperantly.I never said Ford couldn’t put a V-8 in a Ranger
I said I doubted they couldn’t sell enough to make a profit. And Ford only stays in business making a profit (GMC and others, of course, get gov't bail outs).
To put a V-8 in a Ranger, you would be adding just over 200lbs (160 front/40 rear) to the truck, adding 65hp/120ftlb of power/torque.
Over a dozen teams would need to get involved if you were doing it internal to Ford
Vehicle dynamics:
Frame group:
- Perform analyses and determine what needs upgrading
Suspension group-rear:
- Review if material thickness increase required by torsional/bending analysis
- Modification to the engine mounting location for V-8 mounts
- Modification for remote oil filter
Brake group-rear:
- Upgraded axle to handle additional torque (I’m not sure if the 31 spline axles/large bearing of the Explorer axle were available in Chassis Cab, though they just had “Ranger” 8.8s)
- Revised spring rates for higher weight
- Revised shock damping rates (do you need “quad shocks” ala Mustang to control axle wrap)
- Revised spring rate on anti-sway bar (e.g. 1” bar from Bronco II)
- Revised spring bushings
- Revised anti-sway bar bushings
- Revised axle ratios (if changed axle)
- Revised tire rating selection for higher RAWR/GVWR/GCWR
Fuel System group:
- Revised ABS calibration
- Revised brake size
Suspension group-Front:
- Revised fuel feed line-diameter
- Revised fuel return line-diameter
- Revised fuel pump suction and pressure values for addition flow of V8
- Recertification of emissions due to pump change (FMVSS/EPA regulations)
Brake group-front:
- Revised spring rates for extra weight of V-8
- Upgraded axle- if needed by vehicle dynamic analysis (both TIB and TTB need analysis)
- Revised axle ratios for 4wd (if changed rear axle ratio)
- Revised tire rating selection for higher FAWR/GVWR
- new knuckles due to brake size change and increased tire wear
Exhaust system group:
- Revised brake size due to increased front axle weight
- Revised caliper hose length for revised caliper
Driveline group:
- New exhaust manifold to fit with Ranger engine compartment
- Revised intermediate pipes (true dual exhaust?)
- Revised catalytic convertor and
- Recertify MVSS requirements
Electrical group:
- Strengthen prop shaft as needed and check critical speed and NVH characteristics
- Add 90° adapter to fit remote oil filter
- Add remote oil filter
- New radiator with inlet/outlet/capacity for V-8
- New air filter for V-8
- Update engine harness to accommodate engine change
- Update body harness to accommodate engine change
Body Group:
- Revise ventilation air duct to include “cutout” for the V-8 valve cover
- Revise A/C hoses for V-8 compressor/Ranger air box
- Unique body moldings
- Unique wheels
Documentation:
Vehicle testing:
- Update owner’s manual to include V-8 information
- Update Ranger brochures to include V-8 information
The cost of the above runs into $100M range. Every optional configuration - Manual, 4WD, SCab, Long bed increases cost - bean counters are going to want to see sales to justify the development cost.
- Recertify frontal crash compliance
- Recertification of rear crash compliance due to pump change- (FMVSS/EPA regulations)
- Recertify fuel system integrity compliance
- Recertify emissions compliance
- Recertify misc certifications for Canada
Is Ford going to match Syclone sales with 5k V-8 Rangers? Which would mean an additional $20k/Ranger for your 5.0/auto.
A Ranger in ’90 cost between $8k (RCSB, 2WD, I-4/manual) and $15k (SCSB, 4WD, V-6/auto)
S-10 was a little cheaper than Ranger, so Syclone cost at $32k pretty much matches.
How many of you would have actually bought a $30k V-8 Ranger in ’90?
I actually might have – dual income, no kids, no mortgage at the time (Couldn’t buy a Syclone – they weren’t imported to Canada, wound up with an S-15 Jimmy Tahoe which was as close to Typhoon as I could buy). By ’91, though the ship has sailed – mortgage, single income, kid.
I would like to thank Bob Sheaves for his write up at Allpar for much of above.
Doesn't GT40 count as Fast Ford? And some cars like SHO Taurus might not be "sports" cars but they should qualify.
United States, North America, Earth, Solar System...On what planet does a 5.0 weigh 200 pounds more than the existing V6 offerings?
They made dozens over the life of themThey made a prototype v8 ranger, not sure which ford team did it "svt?". But it was a one of a kind no where close to production.
Okay, I didn't catch that you were including the differences to the rest of the driveline originally. The 4R70 and 4406 definitely add a fair bit. Probably just as much as the difference in engine weight itself.United States, North America, Earth, Solar System...
The difference in weights between otherwise identical 4.0 versus 5.0 Explorers is 205 lbs per Ford documents.
Includes V6 vs V8, 5R55 vs 4R70W and any other bits and pieces (i.e. NVH damper and anti wrap bars).
Hey, for some of us that is almost double the power... my "Best Power in Class" 2.8 only had 110hp and 150lb ft at like 4 grand.To put a V-8 in a Ranger, you would be adding just over 200lbs (160 front/40 rear) to the truck, adding 65hp/120ftlb of power/torque.
