Diagnostic assistance needed
There are 3 O2 sensors on V6/V8 engines
Bank 1 sensor 1 (exhaust manifold)
Bank 1 sensor 2 (this is behind the Cat converter)
Bank 2 sensor 1(exhaust manifold)
Bank 1 sensor 2 is often confused with Bank 2 sensor 1, and a rich condition on this sensor means Cat converter isn't working right
I only have two O2 sensors, and my wiring diagrams doesn't show a third for my particular vehicle.
Sounds like you are having an ignition misfire. Without any test equipment and data my best guess would be the coil pack is bad. The coil pack has 3 coils in it and if one of them shorts it will take out 2 cylinders.
I wouldn't really worry about the codes right now because a misfire can cause rich and lean codes.
I think I'ma have to say you're on the right track. While running diagnostics the other day I had the truck running for a good while and holding rpm around 2-3k, as it got warmer it got worse and gave a noticable sound difference, but it didn't sound like a miss. I can pull plug wires off with the engine running and it acts/sounds totally different. Honestly it sounded like timing was WAY retarded. I'm about to replace the coil just the eliminate it though, cause it could be doing something funny. But I guess the key here is I do have spark on all plugs, but once the coil pack gets hot it could be breaking up.
Just replaced the coil. No change. I tested the TPS and MAF, both voltages were right in spec. This pretty much settles it for me, I think it's the PCM.
