I'm sorry but what is the difference between the Lock-Right and the No-Slip made by Richmond? They both look similar, I've had the No-Slip (8.8 gear) in mine for 35,000 miles and have never regreted getting it. Got my latest one from Rocky Mountain 4x4 for around $400.
Dave
Rear.is it better to have one front or rear if you can only do 1 for the time being?
Jmhm17 if your running lockers f/r or even a l/s ( limited slip ) in the rear end and a locker in the front unless your doing some serious off roading or rock crawling you are going to have more than enough traction to do what ever you want to get into.. with that said i think that you will be suprised at where you rig will take you without a lift.
i mean everyone says what you say, they say full lockers are way more than what i need but why is it im getting stuck in 2 feet of snow? will tires really help me that much? if i get a set of bfg mud's or procomp muds then i shouldent need lockers for the little off roading i do? i dont know maybe im overdoing it.
Locking on an off ramp, what? If you get stuck because you're spinning one tire, a LS wont help, it will still spin one tire, been there done that, not worth the time/money.hmm so a ls might be all i need and maybe a locker in the front.. i just dont want the locker to lock on me on an off ramp or somthing.. but i also dont want to replace the clutches in my l/s if i get stuck.. i mean everyone says what you say, they say full lockers are way more than what i need but why is it im getting stuck in 2 feet of snow? will tires really help me that much? if i get a set of bfg mud's or procomp muds then i shouldent need lockers for the little off roading i do? i dont know maybe im overdoing it.
so hows this sound then.. a ford ls in the rear and a aussie locker in the front? or should i just save my money? i just hate the fact i have an open rear i feel like thats 100% of the reason why i get stuck.. and yes i take my time off roading.. nothing works i always spin, then sink.. then im done..
**i think this thread should be stickied or somthing cause theres alot of good info in here..
What do you have for tires? If you do alot of winter driving mud tires won't be the answer, yeah they are great it loose fluffy stuff and would take care of your 2' drifts, but might as well be slicks on hard packed snow or ice. A decent A/T would be the best option, BFG is supposed to make one of the best, although I really can't complain too much about the Widetrack Baja AT's on my F-150.
Loose the All Seasons for some All Terrains and get back to us, I bet that and a couple tubes of sand will significantly reduce your problems. Unless you are hitting mud don't bother with MT's, like I said before in other wintery conditions they can hurt more than help.
