bambino
- Jun 16, 2011
- Automatic
I have a thread on this already in the Bii forum but I don't have a lot of time to get this fixed. One day off and have two kids that keep me busy enough.
I have an 88 bii 2.9. Have changed the following,
Battery, plugs, wires,cleaned iac, inline fuel filter, coil,tfi, tps and maybe more?
Anyway, truck ideled good in park when warm it would stall ONLY when put in drive or reverse. Pulled codes for tps. Changed it and fuel filter.
Made huge mistake with fuel filter. Thought i had the canister filter. Turns out canister is empty....I broke the dang canister. I figured i would just bypass it. Its useless anyway. So it had two lines in and two out. I'm not sure if i have them reconnected right cause now it won't start. It cranks but won't turn over. I have fuel at the rail but not sure of the psi. I put old tps back in and still won't start.
After cranking a few times without turnning over I noticed the inertia switch needed to be reset again. Could this all add up to a bad switch? Its the first time i had to reset it and this problem is ongoing.
I currently have the break lines disconnected cause one blew a hole. The computer isn't smart enough to pick up on this and tell the engine not to start. Right?
I'm thinking either....
I hooked up the two fuel lines comming from the than going to the high pressure pump or whatever incorrectly....
or
The tps somehow fell out of whack when i took it off.
or
its something else entirely that i will never figure out causing me to go on a killing spree.
Please help....
or
or
Please help....
