bluebombersfan
- Nov 4, 2008
Like I mentioned before I had a mild wobble on my rear passenge tire which I thought was a bent axle shaft but after replacing it and it not going away I realized very quickly that that was not it. I then thought maybe the drum, replaced the drum and now the wobble has magically split between both tires. Good news is the wobble split into both wheels which is barely noticeable now but does anyone have any explanation for this? The only thing that I can think is that there is a strange warp in the axle that may be causing this strang behaviour.
When I get some more time I'm going to try putting the tires on without the drums and see what happens next then after that rotate tires but from my previous tests there was something really strange going on. So yeah the wobble is now a little bit on both rear tires
