- Apr 26, 2009
- Lafayette, IN
- Manual
just got back from a miles total drive and on the way back it did the DW and it wasnt a bump but more of a smooth depression in the road. Im told a weak sidewall of a tire can also cause this. When this does happen, my steering wheel doesnt move but my wheels do and after furture inspection, i think my knuckles were drilled out from the PO of the axle and ran heims. The top of the hole is to wide fot the TRE to fit as it should and may be causing the problem. So my next question is, how hard is it to change knuckles, is it as easy as just taking the 2 balljoint bolts off and it slides down and put the other on? And also, anybody got close up picks of how well the TRE should fit, i assume there should be no space at all. My trackbar mount on my frame hasnt changed position, its welded to the frame, but still flexes.
Also, is it better to run a positive or negative castor, my angle is pointing forward now, but not that much and i have lost my steering returning to center to after adjusting it yesturday, and im told thats not good.
Right now im so paraniod to drive my truck unless its dark out and nobody is on the streets, im just worried that somebody is going to rearend me due to they have to always be driving right on my ass and this being my only vehicle, i would be screwed. Only thing i can do right now due to being at my gf's house is play with the tire pressure.
Ill hopefully be posting pics soon, have to go somewhere and it has internet, been typing on my cell phone.
