Dana 35 TTB center slip yoke vent.
nooch450
New Jersey
I noticed while assembling and cycling my TTB that the slip yoke seems to create a vacuum and pressure inside while it slips in and out and its taking a toll on the little clip inside the passenger hub...
Should there be a vent for air or does anybody have any suggestions?
Sent from my DROID BIONIC using Tapatalk 2
I've never had any issues there myself... Are you running a circlip-eliminator spring? Did you grease the axle end assembly well? (the splined washer where it rests up against the end of the spindle)?
Everything is greased well. And no c clip eliminator here.
I have a ton of plunge with 16-17" travel and at high speed its deff taking a toll on the clip because of the vacuum and compression in the female slip yoke. Should it have a vent hole like some driveshafts and mine is caked over or something?
No, it's not possible to vent it without water, dust and other gook entering into it.
Which "clip" is it you're speaking about? The C-clip that holds the splined washer on at the outer stub axle? Or the E-clip inside the diff? What exactly is happening to the clip?
I ask only because I can't see how that could be damaging either clip (any vacuum or pressure inside the boot is not going to create more than maybe 10-15lbs force on it at the most), the only thing I've ever seen in this area is the splined washers themselves getting chewed up against the spindle, which was why I mentioned greasing it well. If this is what's happening, maybe switching to the '95-'97 3-piece washer setup could help (it uses two steel washers with a Delrin plastic "bearing" between them, rather than the metal-against-metal of the '90-'94 setup).
Well i have a hard time pushing the axle shaft in and out. And yea thats exactly what's happening. The splined washer with the clip is getting chewed up. Ill try that upgrade! Thanks again 4x4junkie!
No prob. :icon_thumby:
Also be sure you're using a moly-based extreme-pressure CV joint grease on the slip-yoke spline (ordinary bearing grease might not be enough for it, which could cause additional strain on those parts).
Good luck on it.
