Dana 35 questions
92NHranger
New Hampshire
So i went to do my u-joints on the passenger side before winter come and my yoke is seized.. does anyone know how much gear oil the 35 takes? It also looks like the left side of the housing is on a pivot point. if i take the bolts off the beam will the pumpkin just come back to me? or will it have to pivot and be a problem because the yoke is seized?
So i tried to rip mine out.. theres a pivot point on the drivers side of the housing that will only come out if the radius arm is off. Thankfully, for the NH winters i could not get my radius arm off after heat and pb blaster. The housing will only move out about 3 inches while its still in place with that pivot bolt in. Good luck if you're trying this yourself.
