nooch450
First let me tell you that the Nitro Instructions suck...
1. What should my backlash actually be Nitro said .006-.010 in install book???
2. The nitro kit came with pinion shims that need to go behind the bearing race (nitro install instructions do not tell you this)... This is bullshit because I pressed the new race in and tapping it out must destort it so i had to buy a new one for final install....
3. The kit came with no carrier shims, the only shims that came out of the diff were on the outside of the carrier bearings between the outer race and housing.(thicker than .120) I put them back in the same way they came out but i cant get the pattern to be sufficient with these shims.
I replaced the pinion shims (the one that goes behind the bearing race) to get the backlash into spec (.006-.010) but my pattern is too deep...
As of now I have no way of shimming my carrier so I ordered 2 differnt shim kits for the carrier. One with the thick looking washers and the other with the thin looking washers. (im not too happy with nitro)
Why does my TTB have external shims on the carrier bearings but the (http://www.therangerstation.com/tech_library/pdf_documents/Dana_Ford_35.pdf) shows them under the carrier bearings?
What does the sleve and thin shims that only fit on the outer pinion bearing shaft do? Does that get used in place of the crush sleve if wanted?
