dana 35 hybrid
an axle from a 91 - 94 explorer. its not quite as easy as a direct bolt in but close enough. snag the 8.8 from a 96 or newer explorer and you can get disk brakes and 31 spline shafts aswell.
ALL you need is a true D35 pumpkin and inner shafts. Drivers side to the stub shaft, and to the slip joint on the passenger side. Everything else is D35. What gearing do you have?
