- Aug 14, 2007
- UT
- 4.0 V6
- Manual
- Total Lift
- 5
- Tire Size
- 33
Because it works?
Because it doesn't work as well, and many RBV owners use the wrong approach.
Because it works?
Mine works quite wellBecause it doesn't work as well, and many RBV owners use the wrong approach.
Off the top of my head the only one person I can think of that had a failure was Sunk because the spring wasn't strong enough or it slipped or something like that.
Doh! It's been so long since I've heard the internal spring discussed I completely forgot about it. Definitely the wrong way to go about it IMO.Mine's been perfect.
Years ago I did have the one on my Ranger pop the cap though (internal spring). Articles stating you can put a spring INSIDE the yoke don't explain there's only like 1" of room in there at ride height, when the axle tries to droop, *pop* it goes. Since going to an external spring, no more issue. So it is true, the method used does make a difference.
Hence, the way to not do it.
Mine's external.
Because it works?
And I've never seen an external spring that managed to effectively seal the slip joint with a boot...
AD
