- Aug 11, 2007
- Stevens Point, WI
- Manual
It is a built rear end meaning stronger then factory and stronger then my 7.5 I have.
The Dana 35 ring gear is 6 tenths of an inch bigger in diameter than the 7.5. Not much strength difference there. The Dana 35 has 27-spline shafts, and the 7.5 has 28-spline shafts. There is a reasonable strength gain from that extra spline. So the 7.5 should be stronger than your 35, unless you have the "Super 35" kit installed...
The cost of fixing or getting a D35 TTB will exceed the money and time that I have that it will take to put my D30 under my truck.
A 35 swap should be much faster than a 30 swap.
Basiclly I'm going for the easiest, quickest, and cheapest set up that will last me mabey another 6-10 years if I'm that lucky.
That would be a 35.
